21594 Diskussionen
Parallel full case on 32-bit wide data?
Geehrter Beitragender II
1.129Aufrufe
Guys,
I just ran into a switch-case where you can "case" on non-constant values. For example:
module silly(input clk, input key, output is_match, output data_out); reg data; reg m; reg d; always @ (posedge clk) begin case (key) // synthesis parallel_case full_case data: begin m <= 1'b1; d <= data; end data: begin m <= 1'b1; d <= data; end default: begin m <= 1'b0; d <= 4'b0000; end endcase end assign is_match = m; assign data_out = d; endmodule
I know people use something like that for "one hot" state machine, but there "case" values are 1 bit wide. I am wondering if you can do that on, say, 32-bit wide data. It seems for me like an easy way to implement a search given that all data is stored in registers and every "word" is unique.
Is that something that would work in real-life? Or am I being fooled by syntax?
1 Antworten
377Aufrufe
There are clearer ways to write the simple compare performed in this code.
The usage of parallel_case seems confusing, because the second case statement is actually overwriting the results of the first. So it's effectively just an inverted priority, no use for this attributes. In addition, I would follow IEEE 1364.1 (Standard for Verilog RTL synthesis) that opts against usage of th full- and parallel_case attributes in synthesized Verilog.
Antworten
