21597 Discussions
Part Status, End Of Life details and Compliance Data
Akash10
Greetings for the day !!!
Could you please provide the following details required for the below mentioned parts.
  1. Part Status (Active/NRND/Discontinued) :
  2. Years to End of Life (YTEOL) :
  3. RoHS Compliance : (Documents)
  4. REACH Compliance :
Mfr Part numbers :
EP3C5EQFP
If there is no plan for End of Life (EoL) for these parts, are we safe to assume that these parts have a lifetime of at least 7 more years ?
Please suggest.
Thanks & Regards
Akash
DhannielM_Intel
Hello Akash10,
Thank you for posting in the community. To provide you with accurate information, could you please clarify whether the Mfr Part number: EP3C5EQFP refers to a specific model or if you are referring to the FPGA associated with this part number?
Dhanniel M.
Akash10
Hi Dhanniel,
Greetings!!!
This is FPGA IC and the description for the same is mentioned below.
IC, SMD, CYCLONE III*ALTERA, EP3C5EQFP
Thanks, and regards,
Akash
DhannielM_Intel
Hello Akash10,
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns. Therefore, I will be moving this discussion to our FPGA Forum. This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Dhanniel M.
Akash10
Hello Dhanniel,
Could you please check with FPGA team for the updates.
Akash
AqidAyman_Intel
Hello Akash,
For Cyclone III devices, new designs are not recommended. You can consider other Cyclone families. Refer here:
https://www.intel.com/content/www/us/en/products/details/fpga/cyclone.html
Aqid
Akash10
Hi Aqid,
For Current Designs is it obselete or will be supported. Could you please check and let me know the YTEOL for the same.
Please suggest.
Thanks & Regards
Akash
FvM
EP3C5EQFP is no valid Cyclone III order code. You are probably referring to a EP3C5E144 type, there are different temperature and speed grades with according to my resources 0 to 1 year to EOL, you might consider a last order if want to support an existing product.
Suggested replacement is Cyclone IV E, EP4CE6E22, 99 percent pin compatible, CLK0 pin is changed to GND in Cyclone IV.
Frank
AqidAyman_Intel
Thank you Frank for your answer.
Hi Akash,
Do you need more clarification on this?
AqidAyman_Intel
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
