Hi team,
I have 2 cyclone 3 device. I wanted to load the jbc file using passive serial mode. I have the following queries
1. Could anybody share how to merge two jbc files.
2. What is the MSEL Pin configuration for passive serial mode and jtag mode.
3. Can we generate jbc file from sof files. If yes how do we do it
4. Can we generate rbf files from jbc . if yes how do we do it
链接已复制
1 回复
passive serial mode uses raw binary files (.rbf). I'm not aware of a tool converting .jbc to .rbf. If you didn't already generate .rbf during compilation flow, you can use Convert Programming Files tool to convert .sof to .rbf.
