21618 Discussions
Pattern inclusion
Hallo there,
I need some help or ideas,
i have a data stream and one time in this stream i have a frame "80008000" the next frame is then a counter value, for example "00000008"
and then again "normal" frames (for me not interesting how they look).
Now when i found this "80008000" i have to read out the next frame (counter value) and then i have to fill in the stream on this location with "80008000" frames. I have to fill in this frame as often as the counter value shows.
How can i do this? Should i take a fifo so that the frames which came after the counter value could be saved for the time i fill in the "80008000" frames?
has anybody an idea how i can do this?
thanks
yes, you either save the incoming frames while you are inserting... or use request signal to stop it...
thanks,
one more question,
how can i read out the frame after the "80008000" frame?
I can search for "80008000" and then i want to read out the frame after that,
how can i realize this in vhdl?
you can use shift register to detect any pattern:
e.g. assuming data_in = 8 bits, for x"80008000" use 32 bit shift register:
on the clk edge:
shift_reg <= shift_reg(23 downto 0) & data_in;
if(shift_reg = x"80008000")then
action...
end if;
take care with byte/shift orientaion(MSB isuses)
--- Quote Start ---
for what are you waiting?
--- Quote End ---
its a spam bot, you should give some negative reps and report the post as spam. :cool:
thanks a lot:D
sorry for my irrelevant post
