21594 Discussions
Pin Assignment failed to be downloaded to the FPGA board
Hi, All,
I am using the Cyclone II DE board and had a strange problem.
Once I changed the pin assignment, e.g., I changed the reset signal from push button KEY0 to KEY1; then I re-compiled the project and downloaded it again on to the board. Surprisingly, when I monitored the signals using SignalTap, it seemed that the "reset" signal was still controlled by the previous setting, namely KEY0, how come??
I tried to download again and again but seems the pin assignment never got changed to tally with my new assignments. I am now really confused, really hope some one could help~ =)
Thanks a lot!
grit
--- Quote Start ---
Hi, All,
Thanks a lot!
grit
--- Quote End ---
first have look into the <>.pin file. It is locaterd in the Quartus RunDir. Search for your signal and check whether the assignment changed or not.
If not, how do you change the assignment ? Using the Assignment Editor ? Which Version of Quartus do you use ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hello, GPK,
Thanks for replying!
Now the problem seems have gone. The solution is that I re-added nodes inside the SignalTap each time I changed the pin assignment in Pin Planner, and then re-compile.
I am using Quartus II 9.0 SP2.
Thanks once again.
--- Quote Start ---
Hello, GPK,
Thanks once again.
--- Quote End ---
I observed a similar problem with Quartus II 9.1. When you use post-fitting nodes in Signaltap the Partition Top ( that is a defalut partition in every project) preserve Level is set to "Placement & Routing" and a new pin assignment will be ignored. Look into your messages, I sure sure you will find an info about this issue.
Kind regards
GPK
