21607 Discussions
Pin assignment problem---FlashRom Open Drain
Now I want to use the Cyclone III starter board to read or write FlashRom,
But when I compile my project ,I encounter many below error.
In the device and pin options, I set all the Dual-Purpose Pins as Use as regular I/O.
Now I cant correct the error.
Please help me.
Thank you!
Error: Following feature(s) of I/O pin FLASH_DATA[15] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B6
Info: The IO feature 'Open Drain' has invalid setting, it should set to OFF
Error: Following feature(s) of I/O pin FLASH_DATA[14] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location A5
Error: Following feature(s) of I/O pin FLASH_DATA[13] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B5
Error: Following feature(s) of I/O pin FLASH_DATA[11] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B3
Error: Following feature(s) of I/O pin FLASH_DATA[10] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location A3
Error: Following feature(s) of I/O pin FLASH_DATA[9] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location E7
Error: Following feature(s) of I/O pin FLASH_DATA[8] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B4
Error: Following feature(s) of I/O pin FLASH_DATA[7] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location A4
Error: Following feature(s) of I/O pin FLASH_DATA[6] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location E8
Error: Following feature(s) of I/O pin FLASH_DATA[5] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location C5
Error: Following feature(s) of I/O pin FLASH_DATA[4] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B7
Error: Following feature(s) of I/O pin FLASH_DATA[3] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location B8
Error: Following feature(s) of I/O pin FLASH_DATA[2] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location A8
Error: Following feature(s) of I/O pin FLASH_DATA[1] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location D1
Error: Following feature(s) of I/O pin FLASH_DATA[0] has invalid setting(s) in configuration scheme ACTIVE_PARALLEL_FLASH when the pin is placed at pin location H3
Error: Can't fit design in device
Error: Quartus II Fitter was unsuccessful. 16 errors, 6 warnings
Info: Allocated 186 megabytes of memory during processing
Error: Processing ended: Tue Apr 29 15:08:31 2008
Error: Elapsed time: 00:00:08
Error: Quartus II Full Compilation was unsuccessful. 16 errors, 94 warnings
The same error has been reported in another thread, I think. However, I don't understand where the Open Drain setting comes from, it seems inappropriate for any possible usage of the flash pins. I'm not using the board nor Cyclone III with AP configuration, so I had no occasion to experience the problem. But I know that the starter board is shipped with a fully operational example project, cycloneiii_3c25_start_niosii_standard that also uses the flash. So I first would compare with the pin configuration used in this project to understand what's wrong with your configuration.
I know that message.
But it does not apporate for my design.
why I cannot upload my design.
is there a global assignment to turn on the open-drain in your design?
Anyhow, you can use individual assignment to turn off the open-drain on the active parallel flash pins.
Anthony
I'm not presently using AP configuration or the Cyclone III Dev. Kit, but as I already mentioned, it may be interesting to examine the Starter Board example designs. They have a configuration setting of active serial although the board doesn't utilize AS at all. It may be a necessary Quartus bug workaround.
