21615 Discussions
Please help me about the Cyclone 3. EP3C10TQ144
EP3C10TQ144
I've never used FPGA.
I have a problem with the use of Cyclone 3.
How to use JTAG.
How DIY JTAG cable that goes from the computer.
Now I have to create your own board.
I do not understand that Q nstatus, CONF_DONE is low at all times.
Program FPGA I have not done it.
But the problem is the AP most of my design wrong I'll try to a JTAG.
And if possible would like to see examples of design
I promise to try to turn to the FPGA.
I don't understand what you are looking for. How can you know that CONF_DONE is low at all times if you haven't created your board yet?
Sorry I'm not good at English Language.
board Completed.
R 4.7k to VCC through CONF_DONE pin.
nStatus, CONF_DONE (and IO_INIT_DONE) should all be tied to VCC with a resistor (10k here).
What tells you CONF_DONE is low?
--- Quote Start ---
--- Quote End ---
I use a Multimeter measure (^_^)
Are you using JTAG to configure it? What does the programmer say?
I think the layout circuit fault.
Please suggest ways to design
In design time I do not have jtag.
You should always have a JTAG connection, it can really help.
How do you configure the FPGA? Check the signals with a scope. You should also read Altera's recommendations and compare them with your schematic.
I is not done it since the beginning.
I was assigned to. But when he came up to me to fix the problem.
I looked at the manual. I saw that what they have done deficiency
Now I have the problem somewhat.
But what I want now is that I want to cut the rest. Out to only FPGA.
Try the program before.
Can't you modify the board and solder a JTAG connector with the required pull ups/downs directly on the FPGA pins? It isn't very nice, but if it is just to test your design...
umm nStatus, CONF_DONE is low all time
IO_INIT_DONE must be R10k to VCC yes or no ?
yes it should be pulled up, and the "enable INIT_DONE output" option must be selected in the Quartus project.
nStatus and CONF_DONE should be pulled up too, and if they stay at 0 it means that the FPGA isn't able to configure itself. Read this document (http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf) for all the recommendations with the configuration signals.
