In ACEX 1K and Cyclone, the power supply don't rise not monotonically.
The waveforms is shown below.
Is the 3.3V in Cyclone "monotonically"?
Also, the 2.5V in ACEX 1K has a slope that is always positive, is this "monotonically"?
Finally, what is expected to happen when power is supplied with these waveforms?
Looks like the decoupling of your design is not optimized.
Please use PDN to check your decoupling capacitor requirements according to your Ztarget and target running frequency.
regards,
Farabi
Just want to know if this setup can make the FPGA successfully configured and enter user mode?
regards,
Farabi
Hello Farabi
Thank you for replying.
If this non-monotonicity, can intel guarantee that the FPGA work correctly?
If not, what kind of defects can be expected? (ex; I/O pins output incorrectly, possible corruption ect)
Inoue
i'd refer to datasheets. ACEX datasheet e.g. specifies "Maximum VCC rise time is 100 ms, and VCC must rise monotonically" for VCCINT and VCCIO.
In other words, the device is not guaranteed to work correctly if you violate this condition. I won't expect damage, but configuration might fail.
As the shown VCCINT and VCCIO waveforms are nearly montonical, I won't expect failure. But it's obviously bad 5V regulator design that should be fixed.
Out of curiosity, are you newly designing with 20 years old ACEX1K and Cyclone or just servicing old instruments?
Frank
As the query has been answered by members, I am setting the ticket to closure. However, it will be open for communication for community members.
