21615 Discussions
Pre-program with BP Microsystems Programmer a device Altera 10M08SAU169C8G
SMTC is using the Altera 10M08SAU169C8G
Here I have an issue to pre-program the part with BP Programmer. (Prior to install on a PCB)
I have two options:
Option1 is to pre-program the device at BP Programmer.
Option2 is to program the device on board using the Quartus JTAG programmer.
In both options I use the same .pof file.
When I pre-program the device with BP Programmer the units PCBAs do not work, they did not boot.
When I program the device with Quartuz JTAG programmer the units work correctly.
Could you, please help me?
I need to know if Quartus perform something else at the end of programming the device.
