Problem PIO
Hello to all,
I'm new in FPGA and I have a Cyclone II and I made a design with a Nios II.
I just want to drive a component (LM629) and I have to send et receive data.
I created a tri state PIO
# define LM629_DON_NAME "/dev/LM629_DON"
# define LM629_DON_TYPE "altera_avalon_pio"
# define LM629_DON_BASE 0x01000010
# define LM629_DON_SPAN 16
# define LM629_DON_DO_TEST_BENCH_WIRING 0
# define LM629_DON_DRIVEN_SIM_VALUE 0x0000
# define LM629_DON_HAS_TRI 1
# define LM629_DON_HAS_OUT 0
# define LM629_DON_HAS_IN 0
# define LM629_DON_CAPTURE 0
# define LM629_DON_EDGE_TYPE "NONE"
# define LM629_DON_IRQ_TYPE "NONE"
# define LM629_DON_FREQ 85000000
# define ALT_MODULE_CLASS_LM629_DON altera_avalon_pio
To send a data I just write IOWR_ALTERA_AVALON_PIO_DATA(LM629_DON_BASE , mydata).... and the problem that it doesn't work, I can't send the data...
I read I have to change the direction of my port and I use IOWR_ALTERA_AVALON_PIO_DIRECTION(base, data)
But finally it's the same thing. :(
Can you help me ??
did you get nios with an altera dev board? Look in the Examples directory within the kit install path for examples that use PIO.
Did you check the header file altera_avalon_pio_regs.h? There are several defines there that can be of interest:
# define IOADDR_ALTERA_AVALON_PIO_DIRECTION(base) __IO_CALC_ADDRESS_NATIVE(base, 1)
# define IORD_ALTERA_AVALON_PIO_DIRECTION(base) IORD(base, 1)
# define IOWR_ALTERA_AVALON_PIO_DIRECTION(base, data) IOWR(base, 1, data)
# define ALTERA_AVALON_PIO_DIRECTION_INPUT 0
# define ALTERA_AVALON_PIO_DIRECTION_OUTPUT 1
I have almost the same problem.
I created a component in Qsys with 3 differently Conduits (sd_clk, sd_cmd and sd_dat) and for this component I have just one Base.
How can I use the function IOWR_ALTERA_AVALON_PIO_DIRECTION(component_base, _____) to write output and input for each of the conduits?
Does anyone have an idea?
Thank a lot in advance!!!
Those functions are only for Avalon interfaces. Conduits, by their nature, are interfaces that don't conform to a standard supported in Qsys, like Avalon. If you want to use those functions, you have to implement Avalon interfaces on your custom component.
--- Quote Start ---
--- Quote End ---
But I implemented Avalon interface for my component. When I created my component in Qsys, the Avalon interface actually appeared automatically and I just added the three conduits to it.
I don't understand. What are those conduits connected to? They are single signals, not Avalon interfaces, so you can't use the functions you mention except for that slave interface.
--- Quote Start ---
--- Quote End ---
These conduits are connected to the PINs of my FPGA board.
I followed this tutorial: http://scale.engin.brown.edu/classes/en2911xf14/qsys_comp.pdf
and did the creation of a new component exactly as the reg16_avalon_interface, the only diference was the three conduits and not just one.
This tutorial doesn't show how to use the functions IOWR_ALTERA_AVALON_PIO_DIRECTION and IOWR_ALTERA_AVALON_PIO_DATA, but I understood that I could do like this:
IOWR_ALTERA_AVALON_PIO_DATA(reg16_avalon_interface_base, 0xFFFF) and IOWR_ALTERA_AVALON_PIO_DATA will not be needed since to_hex (conduit) is an output.
I think it would be the same in my case, but I don't know how to write it in these functions, since I have three conduits (sd_clk : out, sd_cmd : inout, sd_dat : inout) and one of them (sd_dat) is a std_logic_vector of size 4. That means I have 6 signals altogether.
The tutorial shows how to make an avalon interface slave and uses it. But does not show how to use these functions in a software (Nios II Eclipse, which I am using).
Is it really not possible to use these functions for my case?
