Programmable Devices
21602 Discussions
Problem >> How to install modelsim in redhat
hi friends
I have a Problem for install modelsim in redhat linux.I installed it deficultly (becuase i m new in linux) and downloaded modelsim from altera site.(modelsim starter edition)
so, i have 10.1_modelsim_ae_linux.sh and redhat.
altera tutorials says:
tar -xf modeltech-altera-unix-<version number>.tar
cd modelsim/unix
./install.ms
Its worked for me.ad my problem is how could I run it?
./vco
./vsim
./modelsim
didnt worked for my. how could i run it?
$ cd modelsim_ase/linuxaloem $ ./vsim
Thaks so much,
I use starter edition but this error was generated.
Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly.
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
you're not the first one to report that. i will see if i have starter edition installed anywhere so i can try for myself
i am able to start ModelSim-ASE for 10.1 (6.6c) and run vcom without a license. at what point do you see the license error?
this path:
When i type:
./vsim
this error generate:
I downloaded from atera site
