hi friends
I have a Problem for install modelsim in redhat linux.I installed it deficultly (becuase i m new in linux) and downloaded modelsim from altera site.(modelsim starter edition) so, i have 10.1_modelsim_ae_linux.sh and redhat. altera tutorials says: tar -xf modeltech-altera-unix-<version number>.tar cd modelsim/unix ./install.ms Its worked for me.ad my problem is how could I run it? ./vco ./vsim ./modelsim didnt worked for my. how could i run it? ThanksLink Copied
$ cd modelsim_ase/linuxaloem
$ ./vsim
Thaks so much,
I use starter edition but this error was generated. Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly. Unable to checkout a license. Vsim is closing. ** Fatal: Invalid license environment. Application closing.- Mark as New
you're not the first one to report that. i will see if i have starter edition installed anywhere so i can try for myself
i am able to start ModelSim-ASE for 10.1 (6.6c) and run vcom without a license. at what point do you see the license error?
this path:
cd modelsim_ase/linuxaloem When i type: ./vsim this error generate: Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly. Unable to checkout a license. Vsim is closing. ** Fatal: Invalid license environment. Application closing. I downloaded from atera site
