Programmable Devices
Problem with C2H
I have given a long C code to C2H for converting to HDL. On first run it gives error saying something like:
Adrdress range of uart1.s1 overlaps with pll.s1, etc. In this run I used "auto-assign base address" option of SOPC builder.
When I manually configured the base addresses in SOPC builder, C2H gives different error saying:
Exception in thread "System Generation" java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.lang.AbstractStringBuilder.expandCapacity(Unknown Source)
at java.lang.AbstractStringBuilder.append(Unknown Source)
at java.lang.StringBuilder.append(Unknown Source)
at com.altera.utilities.altNode.AltNodeXML$TElement.toString(AltNodeXML.java:853)
at com.altera.utilities.altNode.AltNodeXML$TElement.toString(AltNodeXML.java:794)
at com.altera.utilities.altNode.AltNodeXML.toXmlString(AltNodeXML.java:606)
at com.altera.sopcreport.EnsembleReport.toXml(EnsembleReport.java:146)
at com.altera.sopcreport.EnsembleReport.write(EnsembleReport.java:157)
at com.altera.sopceditor.actions.GenerateSystemEdit.writeSopcInfo(GenerateSystemEdit.java:323)
at com.altera.sopceditor.actions.GenerateSystemEdit$1.run(GenerateSystemEdit.java:193)
at java.lang.Thread.run(Unknown Source)
make: *** [c2h_hdl-t] Error 254
I do not know what to do next. Why this is happening and what can be the solution. Can you give any suggestions?
When I first use C2H in nios ii 8.1,some errors occur .That is because the nios II 8.1 need a path which called "PC-NIOS_II-8.1-0.01.exe". After fix the path, I can use the C2H.
