21615 Discussions
Problem with JTAG
Hi everybody
I've a problem with my MAXII I can't tranfert my program with quartus.
When my CPLD is under 3V I measure an impedance of 10K on TDI and more than 1M for other between ground and th pins.
Now when I plug the USB blaster and an oscilloscope on JTAG pins I have the following result when I press start in the programmer:
TDO: 1.5V peak
TCK: 3V peak
TDI: 3V peak
TMS: nothing
I thougth my CPLD was dead but when I turn off the CPLD there is no more signal on JTAG pins.
Someone have an idea ?
"TMS: nothing" means, the pin is either shorted or the programmer connection broken. You have to fix this first.
P.S.:
--- Quote Start ---
--- Quote End ---
Seems like the design lacks the suggested TCK pulldown resistor.
--- Quote Start ---
--- Quote End ---
I try again to find what's going on this pin.
--- Quote Start ---
P.S.:
--- Quote End ---
I've read that altera device had intern weak pull up/down resistor and that was useless to add external resistor. But I'll try it too.
Thanks for your help. I'll post when I've fix it (or not :cry:).
I've add the pull up and the pull down resistor and when I press start on the programmer
TDO: 1.5 V peak 0 before
TCK: 3V peak 0 before
TDI: 0.6V before then 0V then 3v when I click
TMS: 0V before at 3V
But my device is not recognised, I can't program it.
