21615 Discussions
Problem with .Jam files!
I have a problem playing a jam file by the jam player on windows:
I'm not able to disable the verify procedure on a verify action.
this is an exctract of my jam file (generated by quartus):
ACTION PROGRAM = L0, DO_BLANK_CHECK OPTIONAL, DO_VERIFY RECOMMENDED,
DO_SECURE OPTIONAL,
DO_DISABLE_ISP_CLAMP OPTIONAL,
DO_BYPASS_CFM OPTIONAL, DO_BYPASS_UFM OPTIONAL, DO_REAL_TIME_ISP OPTIONAL,
DO_READ_USERCODE OPTIONAL,
DO_INIT_CONFIGURATION OPTIONAL,
L27;
when i use the options -ddo_verify=0, Jam player still verify!!
(if i place "do_blank_check recommended", i'm able to disable the blank check procedure, so i thnik the problem is quartus in generating jam file.)
Any ideas ??
