21611 Discussions
Problem with Performance Counter Unit
Hi I am trying to measure the number of clock cycles in NIOS2-Eclipse for a C Code using the Performance Counter and I get number of clock cycles as "-1".
I have used Altera's DE1-NIOS reference design and added the performance counter unit using SOPC builder.
My Code is posted below, please tell me what I have done wrong. Thanks a lot.....
Code : # include <stdio.h># include <system.h># include <altera_avalon_performance_counter.h>
int main()
PERF_RESET(PERFORMANCE_COUNTER_0_BASE);
PERF_START_MEASURING(PERFORMANCE_COUNTER_0_BASE);
printf("HELLO WORLD!!\n");
PERF_STOP_MEASURING(PERFORMANCE_COUNTER_0_BASE);
perf_print_formatted_report ((void *)PERFORMANCE_COUNTER_0_BASE,ALT_CPU_FREQ,1,"FFT");
return 0;
Output I get :
HELLO WORLD!!
--Performance Counter Report--
Total Time: 1.84467E+11 seconds (-1 clock-cycles)
| Section | % | Time (sec)| Time (clocks)|Occurrences|
|FFT | 100|184467440737.09552| -1| 100002|
Hi ,
I am facing the same problem . Were you able to solve the problem?
Can anyone tell me the cause of the problem if they have faced similar issue.
thanks.
--- Quote Start ---
int main()
return 0;
Output I get :
HELLO WORLD!!
--- Quote End ---
Not actually but found a work around, i made a new design in the SOPC builder which just had NIOSII Processor, 20KB of On Chip-RAM, JTAG-UART, Performance Counter Unit.
Then I enabled small C libraries in NIOSII-IDE and ran the same code and got the correct cycle count
