I had a design which was working. I decided to add a ddr-sdram (and a clock crossing bridge). Then I ran the same program as before in NIOSII and I have the following general error : Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused Maybe I did something wrong in the System libraries properties ?Or is there something specific to the ddr sdram that I forgot ? Thanks in advance, MyriamLink Copied
