i'am using the Nios II Plugin under Signal Tap II. The Quartus version is 10.0 Service Pack 1. Can anyone help me to answer the next questions ? My first question is: Some Signals from the Nios Plugin are shown in red color. What does this means ? The Plugin seems to work. My seond question is: In my last project, the Nios Plugin only shows "Empty" in the "Address" signals and in the "Assembly Language Mnemonic" signals, too. I know the cases when the Plugin shows "Empty" but olways "Empty" is not ok. Are there known problems in this Quartus version ? Thanks for help, NicolasLink Copied
now, i know the problem, in which case the Nios II Plugin does not work and only shows "Empty" and all signals are shown in red color. I use Quartus 10Sp1. Under Analysis & Synthesis Settings, More Setting, i turned on the "Create Debugging nodes for IP Corres". Now, all nodes for the Plugin were found and Signal Tap with de Nios Plugin runs error free.
