21611 Discussions
Problem with using Inverse FFT Megacore
I have a megacore FFT (length=32768, Buffered Burst) on the fpga and sending it data from the ARM processor (Cyclone V SoC)
I can successfully perform FFT on data.
But when I use the same core to perform Inverse FFT, it fails.
I check output of the FFT core when inverse=1 and inverse=0. Both are the same.
I assert & deassert 'inverse' according to the documentation. That is, there is a pulse for inverse input exactly when there is a pulse at sink_sop. But for the rest of the time it is a '0'
There are no source_errors.
I do not understand why the FFTcore output is same regardless of the input pulse at inverse.
Is there else that I am supposed to do for the Inverse function?
Surabhi
--- Quote Start ---
Surabhi
--- Quote End ---
are you sure about this? I thought inverse input should one value throught its frame
Hi Kaz. Thanks for that. Keeping the inverse at '1' throughout the frame helped. Now it does calculate the Inverse.
I just always thought it was a pulse because in the guide it said " Inverse FFT calculated if asserted. Only sampled at SOP" So I figured it checks for inverse input only at the sop. I guess that was a bad assumption to make.
Thanks for the help.
