21615 Discussions
Problems porting from 11.1 SOPC to 12.1 QSys.
I have recently opened my 11.1 design in 12.1, starting from an Archive (.qar file)
It contains an SOPC builder system, and I want to port it to QSys for various reasons.
I have encountered a couple of minor issues in doing this, but now have hit this problem.
Here is my current flow:
  • Open Quartus, using the .qar as the project. ok.
  • Open QSys from the tools menu. Select the MortonScaler.sopc file.
  • This errors-out indicating that the DDR global resets are not hooked up. Hook them up to external ports to the QSys system. ok
  • Hit Generate
  • This errors out indicating that some custom source files (MeasureDVI.vhd, ru_wrap.v, sh4mbx_core.v, mbxcore.v) are not present. Somehow the archive did not include them. Add these files from the original. ok.
  • Hit Generate again
  • Now this errors out with the error:
Info: altpll_0: Error while generating MortonScaler_altpll_0.v : 1 : Error: DLL ("altpll_avalon") not found
child process exited abnormally
Info: altpll_0: Error: DLL ("altpll_avalon") not found
while executing
"exec clearbox altpll_avalon device_family=ARRIAII CBX_FILE=MortonScaler_altpll_0.v -f cbxcmdln_1355780123425864"
("eval" body line 1)
invoked from within
"eval exec $cbx_cmd "
Error: Can't continue processing -- expected file /tmp/alt5691_5190484615655509375.dir/0021_sopcgen/MortonScaler_altpll_0.v is missing
Warning: Quartus II 64-Bit Generate HDL Interface was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 851 megabytes
Error: Processing ended: Mon Dec 17 13:35:28 2012
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Error: altpll_0: File /tmp/alt5691_5190484615655509375.dir/0021_sopcgen/MortonScaler_altpll_0.v written by generation callback did not contain a module called MortonScaler_altpll_0
Error: altpll_0: /tmp/alt5691_5190484615655509375.dir/0021_sopcgen/MortonScaler_altpll_0.v (No such file or directory)
Info: altpll_0: "MortonScaler" instantiated altpll "altpll_0"
Error: Generation stopped, 1325 or more modules remaining
Info: MortonScaler: Done MortonScaler" with 91 modules, 224 files, 18034244 bytes
Error: ip-generate failed with exit code 1: 8 Errors, 12 Warnings
Info: Finished: Create HDL design files for synthesis
I have not managed to get past this issue in 12.1 QSys.
I have attached the qar file, and the missing HDL files that appear to be necessary to open the QSys project.
Any help is gratefully received.
Hi, I suggest you to remove your current pll from you Qsys system
and then add the version 12.1 of the pll.
