21611 Discussions
Problems with VHDL custom component
I am getting this error message
"Error: Error (10482): VHDL error at xxx.vhd(45): object "\'0\'" is used but not declared <filename.vhd> Line: 45" while generating SOPC system.
Line 45 in the code refers to a generic port declared of std_logic type and initialized to '0'. I have included following ieee libraries
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
In _hw.tcl file I have added the generic port as parameter using
add_parameter P_NAME STD_LOGIC 0 "Parameter"
Any suggestions or clue about the error message will be of great help.
Thanks a lot.
Vinayak
