Protecting EPCS
i posted this in the software forum, but perhaps it's really a hardware issue:
For my project, the EPCS contains all firmware, boot loader & application.
The firmware and bootloader will not change, but the application may, so I would like to protect the EPCS areas that contains the firmware & boot loader.
The firmware MUST be in the lower area of EPCS otherwise it can't be booted from (I believe).
According to cyc_c51014.pdf, only the upper areas of EPCS can be protected, not the lower areas.
So I can protect my application but not the firmware&bootloader (or protect everything).
Is this correct?
--- Quote Start ---
Is this correct?
--- Quote End ---
"the upper areas of EPCS can be protected, not the lower areas."
This is the weired thing when i saw this part of the document. Why Altera try to protect the application part, not the default part? Or just our understanding problem?
