21611 Discussions
Purpose of WIRE buffer in BDF
What is the purpose of the "WIRE" buffer in BDF schematics ?
The reason for asking is related to the Verilog "WIRE", which I understand to be analogous to a VHDL "SIGNAL" (I don't know Verilog).
A previous thread explained "WIRE" to be ~ "a way to connect things", but in BDF you have the graphical wiring tool.
So, if coding BDF, when and why sould the "WIRE" buffer be used ?
In the schematics below, is there a difference between "circuit1" and "circuit2" ?
in1 ----|>----- out1 // circuit 1 - "|>" is a WIRE-buffer
in2 ------------ out2 // circuit 2
--- Quote Start ---
--- Quote End ---
There will be no difference.
--- Quote Start ---
--- Quote End ---
For example when changing names.
Both serve the same purpose. But the Wire buffer has a buffer in between. This can be used to insert delays in the line and also to improve the drive strength / fan-out of such signals.
--- Quote Start ---
--- Quote End ---
It wouldnt do this by default - duplicate logic is usually optimised away, unless specified max fan outs are reached, or attributes/assignments are made. Maybe in old compilers in old technologies would this have been possible without using attributes or assignments.
The wire primitive in BDF doesnt have much more use than a signal re-naming block.
