Hello there,
I am using a DPRAM as component in the SOPC Builder, I just used the DPRAM_TopLevel.vhd from the LPM_megafunction_wizard as HDL-File for the own component (after Avalon-Slave Interface assignments) and it properly worked. I get access to the DPRAM whithout any problems when I use: IOWR(DPRAM_BASE, Offset, 0x12345678); IORD(DPRAM_BASE, Offset); But when I try to dereference a pointer to DPRAM_BASE I cannot write a “word” to the DPRAM. My function is as implemented as followed. volatile unsigned int *ptr; void TestDPRAM(void) { int i = 0; ptr = (unsigned int*)(DPRAM _BASE); for (i=0; i<DPRAM_SPAN;i++) { *ptr = (unsigned int)0x12345678; printf("\Addresse: %x\t",(unsigned int)ptr); printf("\tValue: %x",(int)*ptr); ptr = ptr+1; } } Do you have any advice what is going wrong?Link Copied
