21593 Discussions
Quartus 18.1 - CYCLONE V Preloader issue
syam
Hi
Am working on a project with CYCLONE V - 5CSXFC6D6F31C8N with Quartus 18.1. After compilation in emif.xml file in the hand off folder the SDRAM related clock info is being written as 0 by quartus. The preloader doesn't work therefore.
We had to manually set the value to make it work. But not sure this is the best value. Please suggest appropriate values for these.
Our EOSC input for HPS is 25MHz. We are not using f2h_sdram_ref_clk. Memory clock frequency is 300 MHz.
Best Regards
Syam
syam
Thanks. I will try with the new boot flow and revert with my findings. But note again that it is for the latest version of quartus and not for quartus 18.1. So not sure whether I will land on compatibility issues with quartus 18.1 generated files.
syam
Migrated my FPGA design to Quartus 20.1.1, compiled and generated the RBF and tested with old 18.1 boot flow. The RBF is working.
Then I followed the latest boot flow you suggested. Generated the files required. Now right at power up and boot up I am seeing this error.
I found this article - https://www.intel.ca/content/www/ca/en/support/programmable/articles/000073948.html which points to a similar error. There it is suggested that a bug exist with uboot source code. Also a patch is given. But it seems it is related to Arria10 and not Cyclone V which am working with. But I tried applying it but it didn't get applied. May be because it is intended for Arria10 only.
Any help would be much appreciated.
Best Regards
Syam
aikeu
Hi syam,
How was the attempt in using the latest bootloader?
Aik Eu
aikeu
Hi syam,
I am closing this thread for now. Do consider open another thread for further question.
Aik Eu
KennyTan_Altera
Can you try reopen the thread? If failed, you may open a new one.
