21611 Discussions
Quartus 7.1 Sp1 and DSPBuilder 7.1Sp1
Hallo everyone,
I have a problem with my Installation. I have installed Quartus 7.1 Sp1 and DSPBuilder 7.1Sp1.
If I want compile any Example Model like "singen" an error occured.
The SignalCompiler shows the following message:
Created Quartus II Project C:\altera\71\quartus\dsp_builder\DesignExamples\Tutorials\GettingStartedSinMdl\singen_dspbuilder\singen.qpf
Generating HDL
Analyzing model...
Matlab Error
Java exception occurred:
java.lang.UnsatisfiedLinkError: checkOut
at com.altera.dspbuilder.portmanager.PortManager.checkOut(Native Method)
at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(ModelSerialiser.java:88)
Error during generation: Analyzing Error: See log for details.
Has anyone an idea who is the problem? or where I can found the log file?
So long
Mario
Sounds like a faulty installation to me. You could try re-installing.
Or you could check if your QUARTUS_ROOTDIR environment variable point to a directory containing a dsp_builder subdirectory? This needs to be set or it can't find its DLLs.
And make sure you also install the IP files MegaWizard disk.
I have the same problem, but a reinstalltion of all Altera software components (Quartus II 7.1 SP1, DSPBuilder 7.1SP1 and MegaCore 7.1SP1) does not solve it.
Are there other issues that could cause this java exception?
Thanks for your help,
Bernhard
In the directory %QUARTUS_ROOTDIR%/dsp_builder/bin, there should be a file called PortManager.dll. Is this DLL there?
Yes, the PortManager.dll is there.
But it seems that the method CheckOut, which is a member of PortManager can not be excecuted/linked correctly.
Are there different versions of PortManager.dll available or does PortManager.dll depend on some other files that are missing on my system?
By the way: I am running the software on a Win2000 SP4 operating system. So could there be a problem that PortManager.dll depends on a missing OS dll?
Yes that sounds like the problem.
The release notes for 7.1 state that it requires XP unfortunately. You can use depends from http://www.dependencywalker.com/ to find out what DLLs are missing. It's possible they can be installed onto your machine, but I really don't know.
DependancyWalker shows apphelp.dll is missing und some other problems with modules missing in system specific dlls.
apphelp.dll is XP specific and also the other dlls can not be replaced.
Therefore I guess it is not possible to run DSPBuilder with Win2000 ... :-(
I always had in mind the Altera software would also support the Win2000 OS. Maybe thats wrong for DSPBuilder....
And of course you have MatLab / Simulink & ModelSim simulator installed as well.
Did you install Matlab/Simulink as "read-only"? If so, then it would prevent you from accessing its JAVA class, which DSP Builder needs... You can always try reinstalling Matlab/Simulink...
It's already loaded its classes or he wouldn't have had a Java exception in the first place. (Look at the stack trace in the first post). It's highly unlikely to be anything to do with Matlab/Simulink, but is in fact because DSP Builder only supports Windows XP as is stated in the release notes.
I am having the same issue using Win2K. I've tried going back to versions 7.1 of everything. Using the FILEMON utility from the systeminternals folks shows a curious behavior. In the Signal Compiler/advanced interface hitting the 'Create Project' button works fine but the Synthesis button spawns a process that looks for a file quartus_sh.exe without success. It starts in the Matlab directory. I've had no useful suggestions from Altera's support people over the past 2 weeks.
Is quartus_sh on your path? Try starting a cmd window and just running the command.
If not, does it work if you add %QUARTUS_ROOTDIR%/bin to your path?
Subsequent attempts with FILEMON shows Matlab finding quartus_sh.exe in the proper directory. Once the PortManager.dll is loaded things go south. The install DVD for version 7.1 seems to imply that the software is compatible with Window 2K.
I am having what seems to be exactly the same problem using Quartus II V7.2/DSP Builder V7.2 running under Windows XP Pro SP2. Matlab/Simulink is R2006A. I have checked off most of the suggestions in this thread.
Can you confirm that you've used DependencyWalker and apphelp.dll is not available?
Firstly, I do have Apphelp.dll available in C:\WINDOWS\system32. When I ran DependencyWalker on PortManager.dll, this produced a single message: "Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module." Evidently, this results from 'mpr.dll', which is buried 7 levels down in the call hierarchy. My problem, under WinXP, seems more basic. Yesterday I discovered that if I uninstall the Java runtime environment, Signal Compiler gives me exactly the same messages. It's as though the tool thinks that the JRE is missing altogether.
Java is provided along with MATLAB, so it doesn't matter whether you have it installed separately on your system. If the problem was that Java wasn't there, the Signal Compiler window would not appear. You're definitely getting the following error? :
I also think the mpr.dll problem is a red herring since without it, I think your computer would have other problems - it seems to be quite important to Windows. Only other thing I can suggest is to check your MATLAB console window to see if there are any earlier error messages.
This is everything I see in the Signal Compiler message window:
Info: Generating HDL
Info: Analyzing Simulink model
Matlab Error
at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source)
Error: Error during compilation: Error: Error analyzing model see log for details.
There are no messages from Matlab.
Can you tell me what happens when you type this command in the MATLAB console:
java.lang.System.load( 'c:\altera\7.2\quartus\dsp_builder\bin\PortManager.dll'
where c:\altera\7.2\quartus should be replaced with the path to your quartus installation.
Sorry, I can't do this since I'm in the middle of upgrading to Matlab R2006b. Will post again with the result, good or bad.
