Programmable Devices
Quartus 9.1 sp2
hey does anyone know where i can find quartus 9.1 sp2
really need it quick and cant find it anywhere on the altera site?
cheers
Hi there,
check here :
https://www.altera.com/download/service-packs/sps-web.jsp
It said that old version is no longer available for download. I think You should submit a request to download old version.
A similar question was posted here:
http://www.alteraforum.com/forum/showthread.php?t=32063
The 'solution' was to look here:
ftp://ftp.altera.com/outgoing/release
and I see the 9.1sp2 files are indeed in there.
Cheers,
Dave
hey thanks a bunch guys
i found it but i keep getting this error every time i try to compile a vhdl project
*** Fatal Error: Int Divide By Zero
Module: quartus_map.exe
Stack Trace:
0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN)
End-trace
seen this before?
It looks like a bug in Quartus. Unfortunately this version isn't supported any more.
Did you check with the RTL viewer after analysis and synthesis that the code you wrote was properly synthesized? You don't have any big loop that would generate a lot of logic?
