21615 Discussions
Quartus Prime Lite 23.1std crashes on elaboration of a register file
federunco
When synthesizing a project in Quartus with a memory element, it crashes during the MEM entity elaboration, yielding the following error:
Problem Details
Error:
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/vhdl/vhdlvalue_elab.cpp, Line: 3865
_values && pos < _values->Size()
Stack Trace:
0x118e06: vrfx_find_file(char const*, char const*, char const*) (synth_vrfx)
0x2bd6ed: VhdlCompositeValue::SetValueAt(unsigned int, VhdlValue*) + 0x53 (synth_vrfx)
0x2ef1d8: VhdlIdRef::AssignPartial(VhdlValue*, VhdlConstraint*, VhdlValue*, VhdlValue*, Net*, Array const*, unsigned int, VhdlDataFlow*) + 0x59e (synth_vrfx)
0x2e873f: VhdlIdRef::Assign(VhdlValue*, VhdlDataFlow*, Array*) + 0xfb (synth_vrfx)
0x2ead2e: VhdlIndexedName::Assign(VhdlValue*, VhdlDataFlow*, Array*) + 0xbe (synth_vrfx)
0x30eaf2: VhdlSignalAssignmentStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x1ac (synth_vrfx)
0x31573a: VhdlIfStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x5d6 (synth_vrfx)
0x314c9d: VhdlProcessStatement::Execute(VhdlDataFlow*, VhdlBlockConfiguration*) + 0x1e9 (synth_vrfx)
0x2b36f2: VhdlArchitectureBody::Elaborate(VhdlBlockConfiguration*) + 0x122 (synth_vrfx)
0x2b4130: VhdlEntityDecl::CoreElaborate(VhdlSecondaryUnit*, char const*, VhdlBlockConfiguration*) + 0x44e (synth_vrfx)
0x2b9982: VhdlEntityDecl::Elaborate(char const*, Array*, Map*, VhdlBlockConfiguration*) + 0x3f2 (synth_vrfx)
0x13d179: VRFX_VERIFIC_VHDL_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0x1fb (synth_vrfx)
0x132888: VRFX_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0xc8 (synth_vrfx)
0x1b9a03: SGN_FN_LIB::elaborate(BASEX_ELAB_INFO_CORE*) const + 0x193 (synth_sgn)
0x1c34ce: SGN_FN_LIB::start_vrf_flow() const + 0xe (synth_sgn)
0x1c3cd0: SGN_FN_LIB::start(SGN_WRAPPER_INFO*) + 0x720 (synth_sgn)
0x1c843a: SGN_EXTRACTOR::single_module_extraction(HDB_INSTANCE_NAME*, HDB_ENTITY*, SGN_WRAPPER_INFO*) const + 0x10a (synth_sgn)
0x1d02be: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0x14e (synth_sgn)
0x1d147f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist(HDB_ENTITY*, HDB_INSTANCE_NAME*, unsigned long, SGN_WRAPPER_INFO*) + 0x55f (synth_sgn)
0x1d047c: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0x30c (synth_sgn)
0x1dc6f3: SGN_EXTRACTOR::extract() + 0x363 (synth_sgn)
0x1e8362: sgn_qic_full(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::vector<double, std::allocator<double> >&) + 0x2a2 (synth_sgn)
0x209eb: qsyn_execute_sgn(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::string const&, THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x22b (quartus_map)
0x3b0c6: QSYN_FRAMEWORK::execute_core(THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x296 (quartus_map)
0x3eeb2: QSYN_FRAMEWORK::execute() + 0x1b52 (quartus_map)
0x1ddd9: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x881 (comp_qexe)
0x3200e: qsyn_main(int, char const**) + 0x14e (quartus_map)
0x3e5c0: msg_main_thread(void*) + 0x10 (ccl_msg)
0x5c9c: thr_final_wrapper + 0xc (ccl_thr)
0x3e68a: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
0xc096: mem_thread_wrapper(void* (*)(void*), void*) + 0x96 (ccl_mem)
0x91a8: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x5cdf: thr_thread_wrapper + 0x15 (ccl_thr)
0x4058a: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa8 (ccl_msg)
0x29e40: __libc_start_main + 0x80 (c.so.6)
0x1b649: _start + 0x29 (quartus_map)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 22.04.4
OS version: 22
Quartus Prime Information
Address bits: 64
Version: 23.1std.0
Build: 991
Edition: Lite Edition
mem.vhd file:
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
USE IEEE.numeric_std.all;
ENTITY MEM IS
GENERIC(
word_size: integer := 8;
addr_size: integer := 10
PORT (
CLK, RST, CS, WR, RD: IN std_logic;
DATA_IN: IN std_logic_vector(word_size-1 DOWNTO 0);
ADDR: IN std_logic_vector(addr_size-1 DOWNTO 0);
DATA_OUT: OUT std_logic_vector(word_size-1 DOWNTO 0)
END MEM;
ARCHITECTURE behavioral OF MEM is
TYPE reg_type IS ARRAY (0 to 1023) OF std_logic_vector(word_size-1 DOWNTO 0);
SIGNAL reg_file: reg_type;
BEGIN
PROCESS(CLK, CS, RD, ADDR, reg_file)
BEGIN
IF (rising_edge(CLK)) THEN
IF (RST = '0') THEN
reg_file(0 to (2**addr_size)-1) <= (others => (others => '0'));
ELSIF (CS = '1' AND WR = '1') THEN
reg_file(to_integer(unsigned(ADDR))) <= DATA_IN;
END IF;
END IF;
IF (CS = '1' AND RD = '1') THEN
DATA_OUT <= reg_file(to_integer(unsigned(ADDR)));
ELSE
DATA_OUT <= (others => 'Z');
END IF;
END PROCESS;
END behavioral;
RichardTanSY_Altera
The problematic code seems to come from this line:
This is due to the old code running in Quartus synthesis tool and there is no plan to fix/change it.
Try to change the code construct to below code and it will pass the synthesis:
LIBRARY IEEE;
ENTITY MEM IS
GENERIC(
PORT (
END MEM;
BEGIN
BEGIN
IF (RST = '0') THEN
-- Original code
-- reg_file(to_integer(unsigned(ADDR))) <= DATA_IN;
-- Alternative
for i in 0 to (2**addr_size)-1 loop
if to_integer(unsigned(ADDR)) = i then
reg_file(i) <= DATA_IN;
else
reg_file(i) <= reg_file(i); -- Redundant assignment to maintain synthesizability
end if;
end loop;
END IF;
END IF;
ELSE
END IF;
END PROCESS;
END behavioral;
Richard Tan
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support. We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to let us know.
Thank you for reaching out to us!
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
