Programmable Devices
告知
21615 ディスカッション
Quartus .SOF Missing
名誉コントリビューター II
7,777件の閲覧回数
I am new user of Cyclone SOC and i have designed a simple project for LEDs, it is working well but when i have tried to program on my FPGA board the .SOF file was missing. I think i could not find it anywhere in my system. Please help me in this regards.
Thank you !
Shahbaz
0 件の賞賛
13 返答(返信)
名誉コントリビューター II
5,050件の閲覧回数
This file is located in your project folder after you successful compile your design. Especially after the assembler generated the programming file. If errors occure no programming file will be generated.
名誉コントリビューター II
5,050件の閲覧回数
There is no error as compilation was successful, the file should be in the project output folder, but there is no such file exists. I am using Quartus II 12.1 it is licensed.
名誉コントリビューター II
5,050件の閲覧回数
Under Assignments/Settings/Compilation Process Settings you can define an output file directory for your project. Maybe this is done.
名誉コントリビューター II
5,050件の閲覧回数
Furthermore you can look at the Processing Message window for an info like:
Info: Assembler is generating device programming files
名誉コントリビューター II
5,050件の閲覧回数
Well, i have tried this as well but not working.
名誉コントリビューター II
5,050件の閲覧回数
Take a look at your Quartus II Tasks Window.
Are you in the Compilation flow? Can you see the Assembler task under Compile Design?
Is it green?
名誉コントリビューター II
5,050件の閲覧回数
--- Quote Start ---
Is it green?
--- Quote End ---
Yes, the following tasks are green
-Fitter (Place and Route)
-Assembler (Generate programme files)
-TimeQuest Timing Analysis
Moreover, i have design two programs before this one, they were generating .sof but this program is not generating any .sof file.
名誉コントリビューター II
5,050件の閲覧回数
Under the Compilation Flow the following task is not green.
- EDA Netlist Writer (i have got one warning message)
Warning (199027): Can't generate output files. Specify command-line options to generate output files, or update EDA tool settings using GUI or Tcl script.
Could you please help me how to fix this warning ?
名誉コントリビューター II
5,050件の閲覧回数
First of all, go to assignments -> settings -> compilation process settings and make sure that "run assembler during compilation" is ticked.
You can always manually run the assembler by going processing -> start -> assembler
名誉コントリビューター II
5,050件の閲覧回数
--- Quote Start ---
--- Quote End ---
Yes , i have checked that option, assembler is working fine but there is one warning under EDA netlist writer
i don't know how to fix this warning.
名誉コントリビューター II
5,050件の閲覧回数
Maybe you can post screenshots of your EDA Tool Settings page and the pages below.
名誉コントリビューター II
5,050件の閲覧回数
--- Quote Start ---
--- Quote End ---
Here are the attached screenshots of my EDA Tool Settings. please have a look.
名誉コントリビューター II
5,050件の閲覧回数
The screenshots looks ok to me. In your case i would try to create the project new and copy the HDL files to the new project.
返信
