21613 Discussions
Quartus Settings File
I want to maintain a folder for constraints. I am using quartus in tcl mode. Is there any option in tcl, mentioning the exact path for constraints.
For Example :-
I have this directory structure like
RTL -> For all RTL Files
Constraints -> Contains all the constraints
Program -> Contains all the .sof and -.pof files.
I like to mention in .tcl file that the constraints are available in Constraints folder.. How do I do that,,,, Is there a solution for that ??/
Plz let me know...
Waiting for an early response.
Sri.
Hope I've understood the question.
I think you need to do the following...
set_global_assignment -name SDC_FILE Constraints/my_constraints.sdc export_assignments
Thanks a lot for the reply...
But What I need is .....
Can I read the settings file from a directory ??? ......
Let us say.....
If I write all the settings in a file named constraints.qsf which in a directory named Constraints /......
Now from the .tcl file can I intimate the tool to take the constraints.qsf file from the Constraints directory ....
Please let me know..
Sri.
You may wish to consider breaking a bit from your traditional approach. What I have typically done is keep all the Quartus project files in one folder:
my_project
---rtl (source code)
---altera (.qsf,.qpf,.sdc)
---generated (files generated by Quartus during compilation), you can specify this in the project assignments
Jake
