21615 Discussions
Quartus Simulation - initializing registers
Hi guys, I'm new to the FPGA scene and could use some help.
I'm designing a project using Verilog HDL. This project derives some computations from previous data stored in registers (reg type).
I'm trying to run a simulation for verification and I want to initialize these registers to a certain value. I've inserted the registers to the .cvwf file and set their values. However when I run the simulation all the registers are zeroed.
How can I manually set those registers' value?
Thank You.
If you're just doing it for simulation, you can:
a) - initialize the register in the declaration like:
reg my_reg = 32'hdeadbeef;
b) - Create an initial block within your code.
reg my_reg; initial begin my_reg = 32'hdeadbeef; end
c) - You can also create a macro that you only define for simulation that initializes the code
reg my_reg; `ifdef SIMULATION always @(posedge clk or negedge reset_n) if(!reset_n) my_reg <= 32'hdeadbeef; `endif
Jake
Okay I'll try your suggestions.
But just to humor me, is there a way to initialize the registers in the .cvwf file? (Like I would set the clock signal or the reset etc.)
Thank you.
