21619 Discussions
Quartus can't find shared library
I just installed on a fresh install of the latest Debian.
I get:
quartus: error while loading shared libraries: libpng12.so.0: cannot open shared object file: No such file or directory
So I do:
locate libpng12.so.0
/lib/libpng12.so.0
/lib/libpng12.so.0.44.0
I think these files would usually be in /var/lib?
Suggestions would be appreciated.
Marion
Make sure the QUARTUS_ROOTDIR_OVERIDE environment variable is set to the location of your Quartus installation. Try adding /lib to your LD_LIBRARY_PATH environment variable. Try running ldconfig.
Thanks for your prompt reply.
I think I have set up the variables as you suggested, but no joy.
~:echo $QUARTUS_ROOTDIR_OVERIDE
/alt
~:echo $LD_LIBRARY_PATH
/lib
~:/alt/quartus/bin/quartus
rut/lib\:ll *png*
lrwxrwxrwx 1 root root 18 Feb 24 08:45 libpng12.so.0 -> libpng12.so.0.44.0
-rwxrwxrwx 1 root root 155360 Feb 15 10:09 libpng12.so.0.44.0
I guess I should have accepted the default location?
Thanks again for your help.
Marion
Sorry, that was supposed to be QUARTUS_ROOTDIR_OVERRIDE (two r's in override), and it looks like in your case it should be set to /alt/quartus, ie it should be able to be started with ${QUARTUS_ROOTDIR_OVERRIDE}/bin/quartus
Thanks again for the prompt response.
Unfortunately, I have still not been able to get it to work.
I did read the installation guide and learned that I should have put the ..quartus/bin
directory in my path. So I did that, but it still didn't work. I don't think that was the problem, though.
Next I deleted the whole /alt directory with the idea of going for the default location,
but when I tried to install that way, I got:
rut/home/mr/Downloads\:ls
11.1sp2_259_quartus_free_linux 11.1sp2_259_quartus_free_linux.sh
rut/home/mr/Downloads\:./11*.sh
Creating directory 11.1sp2_259_quartus_free_linux
Verifying archive integrity... All good.
Uncompressing Quartus II Web Edition (Free)...................................................................................................................................................................................................
./setup: 1: Syntax error: "&" unexpected
Thanks again for any suggestions.
Marion
If you're on a 64 bits Linux, try "export QUARTUS_64BIT=1"
Alex
Hi Marion,
--- Quote Start ---
--- Quote End ---
Solution# 1: Stop using Ubuntu. Its not supported by Altera, and if you have any problems with the tools, you're unlikely to get help. Just install Centos 6.2 and everything will work correctly.
Solution# 2: Ok, so you want to keep using Ubuntu. Even though you get an error, the archive was unzipped ok, so the next step is to:
cd 11.1sp2_259_quartus_free_linux sudo /bin/bash ./setup and follow the GUI prompts. You may however get additional library library errors because Ubuntu is not supported.
Cheers,
Dave
--- Quote Start ---
Alex
--- Quote End ---
Great reply, this worked for me :-D
- Using Debian 64bit and Quartus 13.1
I am using Debian 9.3 with Quartus 17.1. I had the libpng12 issue (Debian is using libpng16). I ended up building libpng.....
git clone https://github.com/glennrp/libpng.git
cd libpng/
git checkout v1.2.59
./configure --prefix /usr/local
make
sudo make install
If it still has issues, copy libpng12.so to /usr/lib/x86_64-linux-gnu/
My /usr/lib/x86_64-linux-gnu/ looks like this......
ls -l libpng*
libpng12.so -> libpng12.so.0.59.0
libpng12.so.0 -> libpng12.so.0.59.0
libpng12.so.0.59.0
libpng16.so.16 -> libpng16.so.16.28.0
libpng16.so.16.28.0
HMedi2
This worked for me. i'm used debian 10 buster.
