21602 Discussions
Question about Audio Codec Usage in DE 2 Board
Hello Everyone,
I had a problem with ADC inside Audio Codec inside DE 2 board. I have power down every other components inside Audio Codec in Register R6 except ADC. But I get something like this in the signal tap. I have attached a screenshot in the attachment. Should I expect that ADCDAT should output "ZERO" if nothing is powered on? I am confused about the output from AUD_ADCDAT.
I attached some code for I2C controller for Audio Codec here:
always @(posedge END) begin // ROM= 16'h1e00; ROM= 16'h0c0b; //power down ROM= 16'h0ec2; //master ROM= 16'h0814; //sound select -- make it MIC -> ADC -> DAC -> LinOut ROM= 16'h1000; //mclk ROM= 16'h0017; // ROM= 16'h0217; // ROM= {8'h04,1'b0,vol}; // ROM= {8'h06,1'b0,vol}; //sound vol //ROM= 16'h1e00; //reset ROM= 16'h1201;//active DATA_A=ROM; end
There are just a few changes to Register compared to Altera Provided DE_I2sound sample. Can someone explain why I am having output from AUD_ADCDAT.
Any idea is welcome here.
Chen Huang
bump bump!
need help.
Hi Chinux,
I wish I could help you but I can't. I had the similar problem like you. I needed some ADC for my design. There is ADCs on ADV7181B chip but they are for video signals especially. I also asked for advice on using ADC on Audio Codec usage but I did not get any real answer. So I gave up.
Tell me why you need ADC, for some audio signal or for your particular design?
Thank you very much,
Bojan
