21602 Discussions
Questions about TR4 PCIe reference design
I would like to design a PCI Express design with the Terasic TR4 FPGA Development Kit by referring to TR4_UserManual.pdf.
I would like to run the "PCIe Fundamental Communication" example described in Chapter 6 of TR4_UserManual.pdf. To do this, I proceeded as follows, as shown in TR4_UserManual.pdf.
1. I connected the PC to the TR4 board via PCIe x4 Cable Adapter (PCA) and PCIe x4 Gen.2 Cable. (Using PCIe0 port)
2. I downloaded the TR4 SystemCD from the Tersic homepage and installed the PCIe driver (PCIe_DriverInstall.exe).
3. I downloaded tr4_pcie0_fundamental.sof to the FPGA and ran PCIe_Fundamental_Demo.exe. I selected "VID = 1172h, DID = E001h" in Selext FPGA Board field, but it says "Failed to connect the PCIE board" error at the bottom.
I had to reinstall the PCIe driver several times and reboot the PC several times, but the results were the same.
I think the device manager does not recognize the PCIe FPGA board (only the "Windriver" appears under "Jungo" in the device manager).
What's the problem?
My PC's operating system is Windows 7 Enterprise K (64bit) and the board I use is TR4_230.
