Ramb16_s1_s1
Hi to all
I'm tring to use a XILINX design but I don't manage to make a RAMB16_S1_S1 with megawizard.
This is the component :
--- Quote Start ---
component RAMB16_S1_S1 is
port (
CLKA : in std_logic;
ADDRA : in STD_LOGIC_VECTOR (13 downto 0);
DIA : in STD_LOGIC_VECTOR (0 downto 0);
DOA : out STD_LOGIC_VECTOR (0 downto 0);
ENA : in STD_LOGIC;
SSRA : in STD_LOGIC;
WEA : in STD_LOGIC;
CLKB : in std_logic;
ADDRB : in STD_LOGIC_VECTOR (13 downto 0);
DIB : in STD_LOGIC_VECTOR (0 downto 0);
DOB : out STD_LOGIC_VECTOR (0 downto 0);
ENB : in STD_LOGIC;
SSRB : in STD_LOGIC;
WEB : in STD_LOGIC
end component;
--- Quote End ---
You need to look for the 'RAM: 2-PORT' IP from the catalog.
Cheers,
Alex
Thanks for your answer.
I've already tried 'RAM: 2-PORT' but I don't know what is these signals :
ENA : in STD_LOGIC;
WEA : in STD_LOGIC; (wren_a I think)
EN(A) - enable
SSR(A) - synchronous set/reset
WE(A) - write enable
"A" refers to port A.
Read "using block ram in spartan-3 generation fpgas (http://www.xilinx.com/support/documentation/application_notes/xapp463.pdf)". With Altera's 2-port RAM IP, you don't need the enable, 'wren' for WE and 'aclr' is available for SSR.
Cheers,
Alex
Thanks for your help.
I've tested this but not work. :confused:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; --library UNISIM; --use UNISIM.vcomponents.all; entity vdp_vram is port ( cpu_clk: in STD_LOGIC; cpu_WE: in STD_LOGIC; cpu_A: in STD_LOGIC_VECTOR (13 downto 0); cpu_D_in: in STD_LOGIC_VECTOR (7 downto 0); cpu_D_out: out STD_LOGIC_VECTOR (7 downto 0); vdp_clk: in STD_LOGIC; vdp_A: in STD_LOGIC_VECTOR (13 downto 0); vdp_D_out: out STD_LOGIC_VECTOR (7 downto 0)); end vdp_vram; architecture Behavioral of vdp_vram is component RAMB16_S1_S1 is PORT ( aclr_a : IN STD_LOGIC := '0'; aclr_b : IN STD_LOGIC := '0'; address_a : IN STD_LOGIC_VECTOR (13 DOWNTO 0); address_b : IN STD_LOGIC_VECTOR (13 DOWNTO 0); clock_a : IN STD_LOGIC := '1'; clock_b : IN STD_LOGIC ; data_a : IN STD_LOGIC_VECTOR (0 DOWNTO 0); data_b : IN STD_LOGIC_VECTOR (0 DOWNTO 0); enable_a : IN STD_LOGIC := '1'; enable_b : IN STD_LOGIC := '1'; wren_a : IN STD_LOGIC := '0'; wren_b : IN STD_LOGIC := '0'; q_a : OUT STD_LOGIC_VECTOR (0 DOWNTO 0); q_b : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; begin ram_blocks: for b in 0 to 7 generate begin inst: RAMB16_S1_S1 port map ( clock_a => cpu_clk, address_a => cpu_A, data_a => cpu_D_in(b downto b), q_a => cpu_D_out(b downto b), enable_a => '1', aclr_a => '0', wren_a => cpu_WE, clock_b => not vdp_clk, address_b => vdp_A, --data_b => "0", data_b => "0", q_b => vdp_D_out(b downto b), enable_b => '1', aclr_b => '0', wren_b => '1' ); end generate; end Behavioral;
This is original file :
library IEEE; use IEEE.STD_LOGIC_1164.ALL; library UNISIM; use UNISIM.vcomponents.all; entity vdp_vram is port ( cpu_clk: in STD_LOGIC; cpu_WE: in STD_LOGIC; cpu_A: in STD_LOGIC_VECTOR (13 downto 0); cpu_D_in: in STD_LOGIC_VECTOR (7 downto 0); cpu_D_out: out STD_LOGIC_VECTOR (7 downto 0); vdp_clk: in STD_LOGIC; vdp_A: in STD_LOGIC_VECTOR (13 downto 0); vdp_D_out: out STD_LOGIC_VECTOR (7 downto 0)); end vdp_vram; architecture Behavioral of vdp_vram is begin ram_blocks: for b in 0 to 7 generate begin inst: RAMB16_S1_S1 port map ( CLKA => cpu_clk, ADDRA => cpu_A, DIA => cpu_D_in(b downto b), DOA => cpu_D_out(b downto b), ENA => '1', SSRA => '0', WEA => cpu_WE, CLKB => not vdp_clk, ADDRB => vdp_A, DIB => "0", DOB => vdp_D_out(b downto b), ENB => '1', SSRB => '0', WEB => '0' ); end generate; end Behavioral;
