Programmable Devices
Real Type
Hey everyone!
I have a problem and I hope everyone can help me: now I don't known that operation of real type in vhdl. for example: if I calculation 3.5/4.5 then result=?.
one more problem is function sin, cos, tan in vhdl.
thanks!
library ieee;
use ieee.std_logic_1164.math_real.all;
http://www.csee.umbc.edu/help/vhdl/stdpkg.html
This should help.
You should consider, that real and respective math functions are only available for simulation and compile time calculations, e.g. generation of ROM tables. But they aren't synthesizable.
I guess that shows how much I have used those functions. I thought about checking that before i posted, but now i just feel retarded. That being said, Altera provides floating point math units as megacores. Or opencores.org may have something useful. Trig functions, depending on precision a LUT may be helpful, or if you google "implement sine hardware" you may come up with some results. Besides that I don't have a clue really. Sorry for not being too useful.
ece.gmu.edu/courses/ECE645/projects_S06/talks/CORDIC.pdf
an interesting result.
http://opencores.org/?do=project&who=cordic
Example of what the link above talks about.
Yes, also Altera has floating point MegaFunctions. But they don't use VHDL real type rather than IEEE or custom specific floating point types.
Thanks everyone!
If you are trying to use Floating point numbers (real) inside an FPGA, there is probably something wrong with the origional spec. Floating point math is horrible and eats up alot of logic.
Try and re-spec the design to used fixed point math instead. It fits right in with what FPGAs do. and then also look at using this package from the IEEE:
http://www.vhdl.org/fphdl/vhdl.html
Its fully synthesisable in quartus, but dont try and use the floating point parts of it, unless you want to clock the design extremly slowly (or use the altera FP units instead.
In addition, its normally best to implement sin/cos functions using a ROM as it is alot more practical. And remember, keep it fixed point.
I have implemented in this forums. But I cannot use floating point (real) . It error only.
Please help.
you cannot use real types in designs. They are for simulation only.
