21592 Discussions
Refresh DDR2 in normal process!
In normal operation, if the READ and WRITE commands are used frenquently, is it necessary to use REFRESH command for DDR2 SDRAM?
And other questions:
1- Which method is better, changing Bank address whenever I issue READ or WRITE command or changing Bank address when the Bank address is full?
2- If I want to run high frequency with my DDR2 SDRAM, which method I should improve?
Now I use the normal bidirectional interface between my FPGA with DDR2 SDRAM.
Thanks in advance!
