Programmable Devices
20735 Discussions
Relationship between EPCS controller and Remoteupdate Megafunction
Hi there,
I am getting confused by the relationship between the EPCS controller and the remote update megafunction:
Does the remote update megafunction contains a EPCS controller in it to interface with EPCS flash? Or Remote update megafunction is the master to the EPCS controller?:confused:
Hua
- There is probably a RSU<->avalon bridge for the NIOS but I do not know its name
- EPCS controller allows communication with the EPCS using the Nios.
- ALTRSU_UPDATE megafunction allows your custom logic to control the booting of the FPGA
- ALTASMI_PARALLEL megafunction allows your custom logic to communicate with the EPCS device
So if you have a NIOS use the first two. If you donßt, use the last two.
Thanks! :D
