20400 Discussions
Reliability Data - Industrial vs Automotive Rated Temperatures
Ivo1
I have a question with regards to Intel MAX 10 reliability data (2021): are there any differences between the Automotive or Industrial reliability levels since the Operating Temperatures are different? (i.e. more specifically 10M04DAF256I7G vs 10M04DAF256A7G). Can the assumption be made that all MAX 10 components have the same reliability levels?
Thank you in advance for your help!
Ivo
Farabi
Basically, yes, the reliability level are the same as it is the same die. However, because of package difference, the Automotive grade can support up to 125'C compare to Industrial grade which is 100'C and Commercial grade which is 85'C.
regards,
Farabi
NazrulNaim_Intel
I wish to follow up with you about this case. Do you have any further questions on this matter? Please feel free to let me know if there is any concern so that we could further assist you.
Otherwise, this thread will be marked as inactive and will be transitioned to community support because there is no update received from you in a while.
Thank You.
Nazrul Naim
