Programmable Devices
21602 Discussions
Remote system update for arria10 FPGA
Rk_Athram
we are using Arria 10 FPGA DEVICE "10AX057N2F40E2SG", we needed to use Remote system update feature for our custom board.
From the intel design store, there are two reference design modules.
But from rocketboards website it is stated as
https://www.rocketboards.org/foswiki/Documentation/RemoteSystemUpdateCompatibility
"The Remote System Update (RSU) is a feature available for Stratix 10 and Agilex FPGA devices"
please Clarify whether Arria10 will support or NO!
Rajesh
JingyangTeh_Altera
Hi Rk_Athram
Sorry to inform you that the Remote System Update is only for Stratix 10 and Agilex 7 devices currently.
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
From the given link below, There is an example design for RSU.
https://www.intel.com/content/www/us/en/design-example/714766/arria-10-intel-fpga-remote-system-update-via-pci-express.html
which is posted in 20-01-2021.
From your statement
"Sorry to inform you that the Remote System Update is only for Stratix 10 and Agilex 7 devices currently"
is intel not supporting now this feature for Arria10 devices???
Rajesh
JingyangTeh_Altera
HI Rajesh
Sorry for the wrong information.
There is indeed a Remote update IP for the Arria10.
So far here are the document that I am able to find out related tot he IP
https://www.intel.com/content/www/us/en/docs/programmable/683695/18-0/avalon-mm-in-remote-update-core.html
Please give me some time to try out the example for the Arria10 to better help you out.
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Thank you for the response.
Please try out on RSU over PCIe, will be waiting for your results on RSU over PCIe.
I will go through the document.
Thanks and Regards,
Rajesh
JingyangTeh_Altera
Hi Rajesh
Sorry that I have not much to update currently.
I would need more time on trying out the example.
Will update you as soon as i got an update.
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
We have tried the example design at our end but we are getting error.
Please refer the thread for error details
https://community.intel.com/t5/Programmable-Devices/Facing-Issue-On-Design-Example-Intel-Arria-10-FPGA-Remote-System/m-p/1283715#M80022%3Fwapkw=RSU_over_PCIe%20driver
Please suggest how to overcome the error.
Thanks and Regards,
Rajesh
JingyangTeh_Altera
Hi Rajesh
Sorry for dragging the case too long.
Update on this case so far, I am still having problems with the example design.
I am pulling in a more senior colleague of mine to help out with the case.
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Thank you for your efforts.
Please share the results after the tests, why the design is NOT giving expected output.
Rajesh
JingyangTeh_Altera
Hi
Sorry I have no update for this week.
I am still waiting for a reply from our internal engineering team.
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Please update me once you receive the solution/any modification required in the example design.
Rajesh
JingyangTeh_Altera
Hi Rajesh
Before you start the steps of flashing the application image did you flash the ru.jic image to setup the flash layout?
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Yes, we are maintaining factory image, by programming ru.jic.
Rajesh
JingyangTeh_Altera
Hi Rajesh
Did you flash the initial image to set up the image layout for the Factory and the Application Image?
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Yes
Is example design working for you!
Rajesh
JingyangTeh_Altera
Hi Rajeesh
Sorry for the late reply.
I just tried out the example design and found that the files in the example design is not working.
I will work with the owner on this.
Mean while you could try out the files attached.
I have created it base on the user guide of the example.
Please refer to the .map for the start and end address.
jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
I think you missed  files attachment/ link.
Rajesh
JingyangTeh_Altera
Hi Rajesh
The files are up now in the case comment previously.
Could you try check it out again?
Jingyang, Teh
JingyangTeh_Altera
Hi Rajesh
Any update on this case?
Did you manage to try out the files that I have shared?
Jingyang, Teh
Rk_Athram
Hi Jingyang, Teh
Still the attachment is missing.
Rajesh
JingyangTeh_Altera
Hi Rajesh
So sorry that you could not see the attached file.
Let me reattach it here.
It is a zip file case.zip and the content of the zip are as follows:
Jingyang, Teh
