I have written a remote updater (called updater hereunder) using Xmodem 1k protocol. I can upload images but I see that new image (called application hereunder) is configuring the FPGA correctly but my NIOS II program which is also part of this image is not running. I have the following questions which could help me solving this problem: - In the remote updater (updater) I have set the configuration mode to Remote in the Device and Pin options. Is this correct ? - In the image (application) that I will download I have set the configuration mode to Standard in the Device and Pin options. Is this correct ? - Do I also have to add a remote update component to the application image for making the update run ? - In the updater image I have located the epcs-controller on address: 0x0002_1800 and in the application image I have located the epcs-controller on address: 0x00000000. Could this be a problem ? Could anybody give me some hints in order to solve my problem. Thank you and best regards, WamorLink Copied
