21585 Discussions
Removing a component from QSys/SOPC
I have a design in which I created a couple of custom Avalon peripherals on Qsys. One of those peripherals is redundant to this or any future design.
I would like to delete it from the component library view.
How do I do this?
As far as I understand the custom components are added when QSYS starts up by browsing the given IP folders for .tcl files. Therefore, to remove a component simply delete or rename the extension of the .tcl file
Thank you. I will try that.
Qsys and SOPCB search for components by looking for .tcl and .ipx files. It looks in a few place for these files but the most common place is in a subdirectory of your hardware project called /ip
By default one level deeper will be searched relative to where the tcl/ipx file is found.
Yes. That seems to be the case.
Thank you.
