Hello folks,
We currently use epcs4 as altera FPGA's configuration device, but the price of epcs4 is quite expensive. I found that ST's m25p40 can be used to replace the epcs4 in this link:http://fpgaforum.blogspot.com/2006/03/any-replacement-for-altera-epcs_19.html And I found in some designs, m25p40 is used as the configuration device. But in the datasheets of EPCS4 and m25p40, I found there is a difference about instruction "Read silicon ID" between them: EPCS4: 1010 1011 (ABh) M25P40: 1001 1111 (9Fh) I'm wondering whether there is any problems if using M25P40 to replace epcs4, as the "Read silicon ID" instructions are different. Thanks! Br, TangLink Copied
You didn't read the M25P40 datasheet thoroughly. It's also supporting the 0xAB instruction. If I remember right, both chips have even the same manufacturer ID.
