21592 Discussions
SD/MMC controller and ACP possible?
I am trying to get the SD/MMC controller to work with the ACP ID mapper.
Everything seems to work fine if I use uncached SDRAM or OCRAM for descriptors and buffers.
But I can't get coherent access over the ACP to work.
I have successfully setup the ACP ID Mapper for dynamic configuration. This works fine with EMAC DMA as well as custom devices from the FPGA. (I also tried a static configuration for the SD/MMC controller, but this didn't seem to make a difference).
I am using the address >= 0x80000000 and tried different settings of ALT_SYSMGR_SDMMC_L3MST_ADDR.
But the SD/MMC controller refuses to access the cache.
I am surely missing some magic setting that is required for SD/MMC to ACP access to work. Maybe it is related to the AHB bridge?
Peter
