21611 Discussions
SD card interface
I want to add a SD card reader to the hardware of a cyclone3. I have the JTAG/ISP SPI interface wired out.
If the system is booted from flash, can I bolt a SD card reader to the programmer interface somehow? (for FAT)
Or do I need more pins?
If you mean the jtag pins (tck, tms, ...) the answer is No. Those are dedicated pins and you can't use them. You need to wire out any other general purpose I/Os.
--- Quote Start ---
--- Quote End ---
Yes, and the FlashNCE, and data pins.. Thanks for the reply!
FlashNCE and data pins are dual purpose pins and they can indeed be used as GP I/O pins.
You have to set them as generic I/O in the device configuration assignments
--- Quote Start ---
--- Quote End ---
Ok, so you would program those with the file?
If you set these dual-purpose pins as "Use as regular I/O" in the Quartus project settings, you can use them like any other I/O pin.
The configuration file instructs the fpga to initialize them in the orrect way.
After this, is up to your design to control them for your specific purpose.
