21611 Discussions
SDRAM sharing between qsys components
Hello guys !!
I have to use a SDRAM controller in my QSYS system. In have to use the same SDRAM both for a nios CPU than the FRAME_READER component. I thought I had to introduce an appropriate offset so that the memory used by the cpu is not overwritten by the frame_reader and viceversa. By the way I can't figure out how to this..
Any suggestions ???
Thank you and have a nice day !
