21611 Discussions
SG-DMA descriptor chain not working.
Hi everyone,
I'm doing SG-DMA for streaming data to LCD.
This is how I do,
SG-DMA memory-to-stream SOPC connection.
descriptor read and write-->DDR-SDRAM
read data -->DDR-SDRAM
created descriptor using malloc.
descriptor 0:
current descriptor pointer: descriptor[0]
next descriptor pointer: descriptor[1]
SOP(start of package) = 1
EOP(end of package) = 0
descriptor 1:
current descriptor pointer: descriptor[1]
next descriptor pointer: descriptor[0]
SOP(start of package) = 0
EOP(end of package) = 1
PARK MODE ENABLE
so this configuration should introduce a loop chain for the descriptor. However its not working unless i put the loop only inside 1 descriptor(current descriptor pointer: descriptor[0]
next descriptor pointer: descriptor[0]).
I just want to make the data stream continuous base on this 2 descriptor. Is it I lost something??
Thanks for any reply. :o
Additional info from my question:
descriptor(0)
current_descriptor : descriptor[0]
next_descriptor : descriptor[1]
descriptor(1)
current_descriptor : descriptor[1]
next_descriptor : descriptor[2]
descriptor(2)
current_descriptor : descriptor[2]
*if I create descriptor above, the data keep looping sending descriptor(2),
*if I change next_descriptor(2) like below to get a loop,
descriptor(2)
next_descriptor : descriptor[0]
*this one will cause the sgdma stop sending continuous data stream.
:confused:
additional info:
DDR(150MHz) -> SG-DMA (100MHz) -> VSYNC DRIVER(100MHz)
SGDMA send 32bits,RGB converter convert it to 24 bits per 1 cycle, and the sync driver covert the 24 bits and send 8 bits for 3 times.
Are you using the default SGDMA (which is "kinda funky"...nice way to put it) or the one described here?
http://www.altera.com/support/examples/nios2/exm-modular-scatter-gather-dma.html
Use the latter and you'll be happier....even if you have to bit-bang the driver for it.
slacker
