21602 Discussions
SOPC New Component Control 7 Segment LED
Hi every body,
I'm a newbie in SoPC. I use DE2.
I want to create a new component connect to Avalon Switch Fabric (ASF).
This component uses to control 7 segment LED.
ASF will create write signal and send writedata to component. Base on writedata my component will control to show on 7 segment LED.
example:
+ when receive writedata [15:0]= 1000 0000 0000 1010
this component will output character "A" (1010) to HEX7
+ when receive writedata [15:0]= 0010 0000 0000 1100
this component will output character "C" (1100) to HEX5
+ when receive writedata [15:0]= 0000 0001 0000 1001
this component will output character "9" (1001) to HEX0
I write my code, but I don't know it is correct or not.
Hope you can help me to correct my code.
Thank you.
my code:
module control_led7seg( clk, reset_n, cs, write, write_data ); input clk; input reset_n; input cs; // Chip select input write; // Write request //write_data: 16-bit --> HHHH HHHH xxxx DDDD //8 bit H to indicate Led 7 segment i //4 bit D to indicate data written to HEX i input write_data; // Write data: 0 1 2 3 4 5 6 7 8 9 a b c d e f reg write_data; reg seg;//Thanh ghi chua data dc write ra HEX reg HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7; always @ (posedge clk) begin if(~reset_n) begin HEX0 <= 'h0; HEX1 <= 'h0; HEX2 <= 'h0; HEX3 <= 'h0; HEX4 <= 'h0; HEX5 <= 'h0; HEX6 <= 'h0; HEX7 <= 'h0; end else begin if(cs) begin if (write) begin case (write_data) 4'h0: seg = 7'b1000000; 4'h1: seg = 7'b1111001; // ---a---- 4'h2: seg = 7'b0100100; // | | 4'h3: seg = 7'b0110000; // f b 4'h4: seg = 7'b0011001; // | | 4'h5: seg = 7'b0010010; // ---g---- 4'h6: seg = 7'b0000010; // | | 4'h7: seg = 7'b1111000; // e c 4'h8: seg = 7'b0000000; // | | 4'h9: seg = 7'b0011000; // ---d---- 4'ha: seg = 7'b0001000; 4'hb: seg = 7'b0000011; 4'hc: seg = 7'b1000110; 4'hd: seg = 7'b0100001; 4'he: seg = 7'b0000110; 4'hf: seg = 7'b0001110; endcase if (write_data == 1'b1) HEX7 = seg; else HEX7 = 7'b1000000 if (write_data == 1'b1) HEX6 = seg; else HEX6 = 7'b1000000 if (write_data == 1'b1) HEX5 = seg; else HEX5 = 7'b1000000 if (write_data == 1'b1) HEX4 = seg; else HEX4 = 7'b1000000 if (write_data == 1'b1) HEX3 = seg; else HEX3 = 7'b1000000 if (write_data == 1'b1) HEX2 = seg; else HEX2 = 7'b1000000 if (write_data == 1'b1) HEX1 = seg; else HEX1 = 7'b1000000 if (write_data == 1'b1) HEX0 = seg; else HEX0 = 7'b1000000 end end end end endmodule
hello.
have you check this source somehow?
you can check it in modelsim( you can download it from Altera web site)
or QuartusII can compile it.
I have found some errors.
1.write_data
it can't be a register. it is an input-bus.
2.syntax
the line "else HEX7 = 7'b1000000"
you need semicolon.
this is just a syntax error.
3. logical error.
you don't have output.
a module which has no output doesn't make sense.
those are my advice as far as I found.
Dear akira,
Thanks for your advice.
Best Regard.
