21615 Discussions
SOPC not updated with Accelerated function
Hi ,
It is expected that NIOS needs to updates the mapping in the SOPC once we compile the Source in NIOS , but this doesnt happen it just updates the component list and doesnt update the pin mappings with the memory .
*** This is expected *** But doesnt happen****
Build the application project again. As part of the build process, the Nios II IDE performs the following
steps:
● Analyzes the function to be accelerated, determining the mapping from C constructs to hardware, and
computing performance metrics
Optimizing the FFT
Altera Corporation 11
August 2008 Accelerating Nios II Systems with the C2H Compiler Tutorial
● Integrates the accelerator into the SOPC Builder system
● Generates the HDL
● Compiles the system in Quartus II
● Creates a wrapper function to invoke the accelerator
● Compiles the software executable
Does anyone had such an experience ? so what was the solution adopted ??
Rav's
