21602 Discussions
SOPC warning- Quartus 12.0-
In my sopc builder I don't use any custom component. But it shows the following error msg.
cpu_0:Custom Instruction components can be edited through the component editor
Is this a problem? In nios ii IDE it doesn't work well (says Leaving target processor paused)
Thanks in advance.
Hi, you are new to NIOS II, aren't you ?
SOPC will be unsupported. It is replaced with QSYS, quite similar. Both get still bugs (path, script, missing...)
Do you work with an Altera developpment board ? DE2-2C35 ;-) ?
--- Quote Start ---
--- Quote End ---
could you post you SOPC (image or file) ?
--- Quote Start ---
--- Quote End ---
After programming flash, it is normal. You can "start" the processor by :
resetting your board, then the proceessor will boot, usually, at the boot sector in a Flash memory
entering "nios2-terminal -g" something like that in a Nios Shell.
